2003 Honda Civic Logo
Posted on Mar 05, 2010
Stock radio how to remove stock radio from 2003 honda civic
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Mar 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
39693
Points
95
Removed the panel below the radio, clips hold it in and you have to yank it out without damage. then there are two 8mm head bolts behind that panel facing up. they hold the whole frame for the audio and climate controls. then push on that frame with your fingers to pop out the whole panel that the radio and the climate controls are mounted to. then simply disconnect the harnesses and remove the climate controls(three screws and the dials pop off). now you can get to the four 8mm bolts that hold the audio unit in.
Free Car Radio Codes for honda civic 2003
is this a question?
if you read the FSM
it states, do not remove battery before getting, the radio code.
says that on most pages in the book.....
if you lost yours its a dealer fix.'
5helpful
Code for radio/cd honda civic 2003
Try to locate the unique code number that will unlock the theft-protected audio system on your 2003 Honda Civic. It probably was imprinted on an anti-theft identification card that you should have received when you acquired the car. The code was printed on a document that came with your owner's manual packet
If you do not have the code, you will need to track down the audio system's serial number. In the case of the 2003 Honda Civic, finding the serial number may require seeking assistance from a Honda dealer. The dealer should be able to determine the audio system's special code number so you can reset the radio. With some newer Honda Civic models, the serial number can be retrieved electronically from the radio.
If you are able to locate the serial number of your 2003 Honda Civic's audio system without a dealer's assistance, you can obtain the special code by going online to the Honda Web site. You must first provide specific information to prove you own the car. For instance, you will need the Civic's vehicle identification number, or VIN, and the audio system's serial number.
When you know what the audio system's special code number is, use the preset buttons on the car radio to punch in the digits. This should reset the audio system, enabling you to resume using the radio and the CD player.
Read more: How to Reset Radio Information on a 2003 Honda Civic ' eHow.com http://www.ehow.com/how_6056947_reset-information-2003-honda-civic.html#ixzz1FGPZq81d
10helpful
Necesito codigo de radio carro honda civic 2003
hola m podrian ayudar a recuperar el codigo de la radio de un honda civic 2003 y no tengo el manual donde lo puedo consegir sin tener que pagar. desconecte la bateria por acidenten y cdo lo prendi m pidio el codigo de la radio.
I have a 92 honda civic and i got a stock radio
you will have to go to a honda dealer and see if the code is in the system
2answers
Need Radio Code for 2003 Honda Civic
remove radio and get the serial # off the radio and go to your local honda dealer and they should be able to help you obtain the code
I need radio code of my honda civic year 2003 sedan lx auto car
the radio will have to be removed to find model and serial numbers, then call Honda.
1helpful
How to remove the radio in a honda civic 2003
go to an auto parts store and purchase a repair manual it will clearly tell you how to remove the radio . read and understand the directions carefully if you have questions ask the partscarrier they often can assist you
Remove radio from a 2004 honda civic hybrid automatic
there should be some screws on the radio side on each you can unscrew them and the whoe piece comes out that should work
Honda Civic 2001 Radio Code
HAVE TO FIND OUT WHY MY 2003-2005 HONDA CIVIC RADIO DOES NOT WORK. REMOVE BATTERY LAST WEEK AND RECODED THE RADIO. WORK FOR A FEW DAYS AND IS DEAD TO THE WORLD. HOW CAN I TAKE THE RADIO/CD UNIT OUT OF THE DASHBOARD WITH EASE. HOW CAN I TAKE THE RADIO/CD OUT AND IN ?
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
