I have a Toshiba NB100 which I use either with I with a philips 170B Flat screen or the in built flat screen. On an irregular basis either screen will go white, and I must reboot. This has also occurred each time it is connected to an EpsonCX8300 printer. I have had the NB100 for >1year and only recently (i.e. the last month) have I been having this issue. Can anyone advise the likely problem? Thanks.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time
mcdevito75 here, Sounds like your moitor is burned out, I would take the monitor to a Staples, Radio shack and have it tested. Monitors are just like a light bulb and do go bad or burn out.
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert. Hope this solution has been helpful?
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
I didn't solve the problem and apparantly you wouldn't have either seeing that you didn't even bother to read what I wrote......so what would I be paying for????
