Small puncture in the freezer compartment, makes a hissing noise, some type of air escaping? Hissing stops when freezer unit shut off. How bad is this damage?
Sylvania Compact Top Freezer Refrigerator Model SE80102-3 SE80102-1 There is a definate air/gas leak coming from the small puncture. Can this be patched or plugged? Sylvania Compact Top Freezer Refrigerator Model SE80102-3 SE80102-1 There is a definate air/gas leak coming from the small puncture. Can this be patched or plugged?
there is gas leaking from the freezer...can this be patched or plugged? Is the gas poisonous to food?there is gas leaking from the freezer...can this be patched or plugged? Is the gas poisonous to food?
You can't post conmments that contain an email address.
Now you know why you should never use anything metalic to remove ice.
Always let the ice warm before using a plastic tool to remove it.
Time to purchase a new freezer perhaps as a hiss usually means a puncture.
If you've punctured a section that allows the refrigerant gas to escape, the following can happen:
1. If you switched the unit off immediately after, then the puncture can be sealed, and the unit 're-gassed'.
2. If the unit was left to run, there is a real possibility that the compressor could sieze, resulting in repair costs that would exceed replacement costs.
From what you are saying the evaporator got punctured. The hissing was the freon coming out of the unit. The unit will not cool even if it was plugged in.
by the time you have bought/fitted new pipework to this unit you could buy a new one.(pipes are too thin to replace and "loy"(alloy putty)only works for a few weeks.tried it.......next time use an antifreeze spray.....
Good day, Gas is not dangerous. But you have a serious problem. Repair is limited to an epoxy repair, or replacing the coil assembly complete. A new dryer filter must be brazed in, The system must be vacuumed out, charging ports installed ect,ect,ect. You can call around to the service companies for a price, but it will be pricey, and you will probably have to take it in.
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
I am very sorry to say that you have pierced the coolant tubing, the hiss you here is the coolant gas escaping. Your Fridge Freezer may be unrepairable because it is very hard to get into the area concerned. Sorry to break the news to you.
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
More than likely you let the refrigerant out. Is there an oily residue? If so you definitely punctured the evaporator. It's time consuming and expensive to properly repair a standard refrigerator sealed system and maintain the chemical stabilty that will prevent future problems. But with those tiny units priced as they are, it's always cheaper to replace them.
Model SE80102-3
SE80102-1
unfortunately a small hole was created in freezer and gas came out.Now exactly what should i do..
i have the sameproblem
