SOURCE: I installed ncomputing gadget very
sounds like a driver issue
if you are having trouble
with your drivers
here is a general look at
the drivers and how to update them
if your computer came with
a motherboard disc the drivers could be on it
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right click update
driver hope this helps
SOURCE: I installed and used the
You need to re-register the software and the devices. Reboot after registration all should work fine. BTW - I'd recommend installing SP3 (will minimize virus attacks due to increase security patches) and contact NC TS for updated X300 software, it's free so they won't charge you for it and your system will be more current.
SOURCE: I have problem with my
My recommendation is to uninstall the vSpace software, reboot, run thier cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied XP SP3 and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Lastly, if Intel Active Management Technology is installed, disable it. This will be listed in the ports section of Device Manager as either IAMT or SOL/COM3. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for X300 on XP is at: ncomputing.com/download/x300.zip. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210. Lastly do NOT forget to register the vSpace software and related XD1 boxes.
SOURCE: X300 internal error code
My recommendation is to uninstall the vSpace software, reboot, run their cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied XP SP3 and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Lastly, if Intel Active Management Technology is installed, disable it. This will be listed in the ports section of Device Manager as either IAMT or SOL/COM3. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for X300 on XP is at: ncomputing.com/download/x300.zip. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210. Lastly do NOT forget to register the vSpace software and related XD1 boxes. Do NOT install from the provided CD, rather download the latest software from the link provided and install straight from that resulting download.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
