Well... It consumes 240 watts of electrical power total so take the audio power specifications with a huge grain of salt, as no audio device puts out in audio power anywhere near what it consumes in electrical power. Heat produced is power consumed, too and nothing is 100% efficient.
In the specs below the only information useful for comparison is in the line I highlighted with >>> <<<<'s as it conforms the closest to the industry standard practice of using:
"X watts into 8 ohms (standard load) from 20 - 20000 hz plus or minus Y db at no more than .0Z% distortion"
The better amps specify vanishingly low distortion specs (0.0x% vs 0.x%) at the cost of being able to claim higher wattage. But they guarantee cleaner sound at the claimed levels.
JVC is being tricky with their choice of a 40 hz lower limit. THAT is the power hungry end of the spectrum. 20 hz is normally the lower limit stated.
"Output Power .............At Stereo operation
Front channels .............55 watts per channel, min. RMS, driven into 4 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN) 30 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN)
>>>>> 30 watts per channel, min. RMS, driven into 8 ohms, 40 Hz to 20 kHz, with no more than 0.8 % total harmonic distortion. <<<<<
At Surround operation
Front channels .............50 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Center channel .............50 watts, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Rear channel .................50 watts, min. RMS, driven into 8 ohms at 1kHz, with no more than 0.8 % total harmonic distortion."
