20 Most Recent JVC FS-D88 Shelf System Questions & Answers
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
JVC FS-D88 Shelf... | Answered on Feb 04, 2011
Hi! please check the plug of the unit if its perfect tight to the power source. The plug or power source may be a little loose thats why its turning on and off by itself. Hope this helps and have a good one!
JVC FS-D88 Shelf... | Answered on Apr 12, 2010
Hello Velile, indicate the model of your Home Theater JVC, to find the best possible solution
Try disconnecting your JVC from the socket, then check that the cables that go to the speakers are well, that they are not peeled or shorted, after checking, reconnect and see if you are still in Protect
If you continue in Protect, I suggest you contact a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Velile, indica el modelo de tu Home Theater JVC, para poder encontrar la mejor soluci?n posible
Prueba desconectar tu JVC del toma de corriente, luego revisa que los cables que van hacia los parlantes se encuentren bien, que no se encuentren pelados o en cortocircuito, despu?s de revisar, vuelve a conectar y f?jate si sigue en Protect
Si continua en Protect, te sugiero te contactes con un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
JVC Audio... | Answered 2 days ago
Hi Mark, so you account for your JVC, you are not reading the CD, should you indicate on the display, "NO DISC", have you tried to clean the lens of the laser reader, with a cotton swab with a little alcohol?
Another possibility would be that you had, low emission of the reader, which could be adjusted, using the necessary instruments
If after cleaning the reader, it does not work, I suggest you look for a specialized technical service
I hope to solve the problem
Hola Mark, por lo que cuentas tu JVC, no esta leyendo el CD, deber?a indicarte en el display, "NO DISC", has probado limpiar la lente del lector l?ser, con un hisopo de algod?n con un poquito de alcohol?
Otra posibilidad seria que tuvieras, baja emisi?n del lector, el cual se podr?a ajustar, utilizando el instrumental necesario
Si despu?s de limpiar el lector, no funciono, te sugiero que busques un servicio t?cnico especializado
Espero logres resolver el problema
https://elektrotanya.com/jvc_fs-d88.pdf/download.html
https://www.manualslib.com/products/Jvc-Ux-D88-4185098.html
JVC Audio... | Answered on May 15, 2019
Unplug the unit for a minute or two then plug it in and try opening again. If that doesn't work try taping on the door while pressing the 'open' button.
JVC Audio... | Answered on Apr 28, 2019
Hello Clyde, you can connect your EQ2 to the JVC RX 8000v
I sent you the user manual of the JVC RX 8000v to guide you
you have to connect it as if it were a cassette
From the Rec Out of the Cover or MD, in the JVC to the equalizer line input and the equalizer line output to Play In in the JVC
this you can see on page 6
I hope you get it connected
Hola Clyde, puedes conectar tu EQ2 en el JVC RX 8000v
te envio el manual de usuario del JVC RX 8000v para que te guies
tienes que conectarlo como si fuera una cassettera
Del Rec Out de Tapa o MD, en el JVC a la entrada de linea del ecualizador y de la salida de linea del ecualizador a Play In en el JVC
esto lo puedes ver en la pagina 6
Espero que logres conectarlo
https://www.manualslib.com/manual/83906/Jvc-Rx-8000vbk.html
JVC Audio... | Answered on Apr 24, 2019
Sorry, no. You must have the JVC MX-DK1 Upgrade disc to be able to upgrade.
JVC Audio... | Answered on Apr 20, 2019
USE PEEL REMOTE ON A SMARTPHONE.
ONCE WORKING YOU CAN COPY TO A UNIVERSAL PROGRAMMABLE REMOTE.
QED.
JVC Audio... | Answered on Apr 07, 2019
Order the service manual directly from JVC.
JVC Audio... | Answered on Mar 20, 2019
8 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
preset individual radio station
  • Audio Players & Recorders
