Quantum drives are now supported by Maxtor. See this link for information and diagrams:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=168019&Hilite=
SOURCE: hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
SOURCE: jumper setting
Jump the middle pins, second set from the right when looking straight on with the power connector on the right.
Worldvet
SOURCE: how do you set the jumpers so that maxtor quantum
http://www.tacktech.com/display.cfm?ttid=379
Please go to this website below it shows you explicitly how to set the jumpers with a picture other info there as well.
SOURCE: i have a maxtor quantum
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
