FixYa.com
Quantum Fireball Lct20  20 GB Hard Drive
All Products > Quantum > Hard Drives
Problems with Quantum Fireball Lct20 20 GB Hard Drive?
Troubleshooting and Support
Solved Problems for Quantum Fireball Lct20  20 GB Hard Drive RSS Feed Post a New Problem
hard drive
i cant find my hard drive on here
1 Solution
quantum fireball 10.2gb
hi i have this hdd but it runs very slow in my celeron 2660mhz pc its a socket 478 and it takes about 5mins to load xp...
1 Solution
having trouble using it as a solo...
I am trying to switch out my old quantum fireball lct 15 20 from an old compaq Presario into a newer computer with a...
1 Solution
fquantum fireball lct15 30 gb
installed it on a newer computer and it only reads it as a 9 mgb drive dont know whats up is there an instalation disk i...
2 Solutions
Slave Drive not recog in my computer but...
I recentlt purchased a 80G hard drive which i tried to use as a slave in a Gateway desktop (the computer Os was upgraded...
1 Solution
Hard Disk Quantum QML20000LD-A
I need to repair a Quantum hard disk (QML20000LD-A) with some important data on it. I have found the electronic demaged,...
1 Solution
Acomdata external hard drive model: phd...
Hi there, I am having some problems with my hard drive. It was working fine and then I was having some problems with...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Quantum Fireball Lct20  20 GB Hard Drive RSS Feed Post a New Problem
quantum fireball 40 not recognised as...
I am currently running my os on a seagate sata 320gb drive. I would like to run my os on my old Quantum 40gb.  No...
Post a Solution
smd burn
smd jb or jd is burnthis is transistor or diode.thans.
Post a Solution
aasy1300
damage smd jb?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
InterfaceIDE/EIDE
Form FactorDesktop Computer
Capacity20 GB
EnclosureInternal
Spindle Speed4,500 RPM
Drive Dimensions3.5" x 1/3H (Low Profile)
Technical Features
Buffer Size128 KB
External Data Transfer Rate100 Mbps
Interface (Detailed)DMA/ATA-100 (Ultra)
Seek Time12 ms
Average Latency6.67 ms
Other Features
PlatformPC
Package Qty.1
Dimensions
Depth5.75 in.
Height.99 in.
Width4.02 in.
Weight1.1 lb.
Quantum Contact Information
Main support number888-827-3378
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
