1997 Volkswagen Golf Logo
Posted on Feb 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key fob / immobilizer not unlocking door
I have a N reg volkswagen Golf and when I tried to press the immobilizer it wouldn't work, although the light on the fob was ok. I opened the car door with the key and the engine started fine but the hazards are now on constantly and I can't turn them off. I have tried locking and unlocking using the key but that doesn't work. When I lock the car with the key it stops but as long as the engine runs the lights flash! Any help would be great as I have just driven an embarrassing 20 miles with every motorist flashing and pointing...
Anonymous
Level 3:
Master:
  • Master 340 Answers
  • Posted on Feb 25, 2010
Anonymous
Master
Level 3:
Master:
Answers
340
Questions
Helped
106244
Points
1064
Sounds like the security part of the system went bad
take the key fob to the dealer and have it reflashed
if that fails replace the security computer or you can disconnect it from the car you won't have the system but the hazards won't come on unless you turn them on
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1536
Points
11
Try opening doors wih key ,first lock them
My renault clio 1998 r reg key fob wont work
hold the cetral locking lock all button down until the doors lock and unlock. The imobilser light goes solid red. At this point you have 10 to press the botton on your key 2 times . the doors will unlock and lock.
2003 VW Golf 1.4,I tried to press the immobilizer to open the car but it wouldn't work, although the light on the fob was ok. I opened the car door with the key, I am able to lock it with the immobilizer...
do an alarm/immobiliser reset.as per the book.or get back, (if, as most drivers in (THE USA)dont have a handbook).........every question regarding VW/AUDI that i answer NOBODY has a handbook.......WHY.
I can use the key fob to lock my all doors plus the boot, however when trying to unlock the car only the drivers door unlocks and I have to use the button in the car to unlock the rest of the doors and the...
Not sure if this is right and don't want to come accross a belittling but have you tried pressing the key fob twice? I'm sure I read somewhere that pressing it once will do the driver's side and that a second push of the same button will unlock the other doors. Unfortunately, I don't have remote central locking on my Golf but hope this helps!
Key fob had new batterry but didnt do anything still dont work
key in door ,unlock/hold key over,windows will go down...wait 30 secs,lock/hold key over,windows will go up,wait 30 secs then press/hold unlock button on fob for 30 secs,you have just reset the system.(needs to be done EVERY time you disconnect battery/key fob...)
16helpful
Mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
Vw golf 1.6 petrol alarm system stopped working with key fob/run the battery down
You do not state year of car.This is for most golfs 98-06.
switch ignition on
insert key to be programmed into drivers door lock
lock vehicle manually
press lock or unlock button
wait at least 1second
press lock or unlock button again
vehicle horn sounds to indicate correct programming.
good luck,barry
2answers
Key fob won't unlock or lock car VW Golf 2000
You probably caused a short circuit when you changed the light. Change fuse #14. Next time, don't turn the lights on until you are finished changing the lights.
37helpful
4answers
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
1helpful
3answers
I need to use my key to unlock the central locking of my car. It worked fine until last night when the drivers side lock will not open the car. I have to unlock the car using the passenger side door.Im...
i also have a MK5 golf tdi with cental locking problem the drivers door wont open from the fob but all the other doors will, i taken the car to a garage last week when it was pluged in to the computer it showed errors they cleared them it sem't to solve the problem now its started again ?
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
