I recommend that you NEVER use the self clean function. This site is full of people who use it and complain of doors that remain locked, boken locks, burnt elements, burnt fans and one 3 weeks ago, a second burned control board. 650'F is just too fierce.
Spray with Easy Off Oven Cleaner. Put a large roasting tray in the oven and tip in a kettle of boiling water into it. Go to bed and next morning, remove the tray and all the grime will rinse off with hot water.
Your manual is supposed to be here, but it is not showing
The main pump motor may not be working. If you cant hear it running, it may be jammed up or burnt out. If you can hear a loud humming noise, its possible its only jammed. You will have to remove the pump and see if any foreign matter has stuck in the pump impellor. If the pump is running, check the small outlet holes in the spray arms, they may be blocked.
did you unplug the unit when you left the house for 10 days, if you did not there is a chance that a lightning storm may be the cause of the problem>>>you can find the same model or newer model here>>www.discountbargainprices.com
HI.When you turn ON your microwave,can you hear if motor is rotating?If you cant hear an ything from the motor..If you can check the terminal button of your oven.You can actually remove both sides of the oven and try to locate the terminal connection if it is engaged properly.Check also the motor.the motor might not be rotating or defective..Thank you for choosing FIXYA>>
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
