I have a 97 grand prix gtp that will start but once its started itll run for a few seconds, then idle rough & shut off. On the other hand if u start it & step on the gas pedal a few times itll hold a idle 4 as long as I want. But then when i go to drive it, it will drive 4 about 500 ft then shut off!! need help
I had the fuel pressure checked, maf sensor replaced, coil packs tested..... iac motor checked out good. I tried 2 drive it after replacin the maf sensor, it drove 4 a few minutes then shut off again. I drove it home rev'n up the engine & blew the motor. I jus got the motor replaced 2day... It drove 4 about an hour and started duin the same thing. Since its a different motor im thinkin it cant be the plugs or injectors.... idk wat it is but its really buggin me i need help would a clogged converter make the car do this? or what else could it be?
