Paxar Monarch 9403 Thermal Printer Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error #704 - Paxar Monarch 9403 Thermal Printer
Martin C
Level 2:
Novelist:
  • Expert 113 Answers
  • Posted on Jun 25, 2010
Martin C
Expert
Level 2:
Novelist:
Answers
113
Questions
Helped
79796
Points
222
704 means that the printer has not sensed a supply mark within the specified number of inches, or that the printer is out of supplies.
You may have a dirty sensor, or the supply isn't being sensed correctly in the printer. There should be a reel that the supplies go by that has a ring or guide on top that clicks when you move it up and down. Make sure that this guide is sitting flush on top of the supplies so that they do not travel.
Lastly, you may be using the wrong sense mark on the supplies for your application. If you have a black mark on the liner of your supplies, you might need to be using a die cut, which is a gap. Each of these can be set inside the printer or through the software that is sending data to the printer.
1helpful
2answers
Polar 78 error message 704 how to solve this message
He's got the same problem with the Polar 78ES.
Error code 704
What does error code 704 mean ?
google make model maybe year and error code
Mar 16, 2015 • Dishwashers
What is error #704
704 is a supply error. You get a 704 either because the supply sensor is broken or is out of calibration, or because you have your supply type on the printer set for something different than what you're printing on.
If the rubber platen roller that turns and feeds your supplies through your printer is too slick, or has a roller wrapped around it - that can cause a 704 error too.
If you have a black line on the back of your supplies you should be set for "black mark". If you have labels that have a space between them, you should be set for "die cut".
Error 704 Check Supply
Check to see that you have the correct supply selected under "supply type". Are you running black mark supplies or die cut supplies? If the supply type selected doesn't match your actual supply type, you'll get a 704 error. It's also possible that the black supply sensor could be broken, or your platen roller (large black roller) needs to be cleaned. Clean it with alcohol.
Headphone socket broken on archos 704
Depends if the circuit board is damaged. If not and competent technicial should be able to repace the socket. If the board is damaged it will need replacing, unfortunatley this is coded to the hard drive so it is only possible if it is performed by Archos
Change my program in archos 704
You can copy files via USB to the 704 using media player in sync mode or drag and drop in windows explorer. Which mode you use depends on what mode the 704 is set.
Im constantly getting an error code of 800 32 704
LOL what is the title of the message box?  It's obviously not a problem with your monitor. In general it would be your OS, security policies, and antivirus or VM controls responsible for that code.
     Moreover, it would be the fact that you don't know to what code 800 32 704 corresponds.  I can't help but think this relates to the problem where 14,000 laptops go missing in airports every week (seen in El Reg, I think) and that you've found yourself with some Emir's work in your lap.  So fat luck to you both.
Archos 704 wifi
NO. the 704 is not flash compatible.
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
MAC Address authentication
Even though this answer is specifically for the DI-704, the steps and concepts are the same for all other D-Link gateways. If you have a modem with a USB connection only, it will not work with any broadband router due to the need of drivers to operate the modem. The key to this type of connection is recycling the power on the cable modem after physically connecting the modem to the D-Link gateway. Before you start: When first setting up the DI-704, only connect the computer that was used when you originally set up your broadband connection. Do not use hubs or switches for initial setup. Once the gateway is up and running, you can easily add additional computers, hub, and switches to set up a more complicated LAN. Summary: Physically set up the DI-704 by connecting your computer to a LAN port and your modem to its WAN port. From the Network Properties Control Panel, make sure your network card is set to "Obtain an IP Address Automatically". Restart your computer. From the Setup page of the DI-704´s web configuration, set the WAN type to Dynamic and check the box to Enable Renew IP Forever. Click Save. From the Tools page click the button to Clone MAC, then click Reboot to apply the changes. Power down both the modem and the DI-704. Power on the modem first, letting it stabilize, then power on the DI-704. Go Online! That´s the quick, down and dirty explanation. For more detailed setup information use the following step-by-step approach below. Step-by-Step Configuration: Step 1 Connect your broadband modem to the WAN port on the DI-704. Use the same cable that was used to connect your computer to the modem. The WAN light on the DI-704 should illuminate, verifying a good physical link. Step 2 Connect the same computer that was originally connected to the modem to an open LAN port on the DI-704. The corresponding port light will illuminate verifying that you have a good physical connection. Step 3 Release and Renew the IP address for your computer. The address you renew should be in the 192.168.0.100 to 192.168.0.199 range. Use the directions below to Release and Renew your IP address. For Windows 95, 98 and Me: Go to Start>Run and enter winipcfg. Click OK. In the IP Configuration control panel, select your network adapter from the drop-down menu. Click theRelease button, then the Renew button to obtain an IP address from the DI-704. The IP configuration information shows an IP address of 192.168.0.104 and Default Gateway address of 192.168.0.1, which is the default IP address of the DI-704. This information verifies the network adapter is properly configured and the computer is communicating with the DI-704 For Windows 2000 and XP: Go to Start>Run and enter cmd. Click OK. At the DOS prompt enter, ipconfig/release and then hit the Enter key to release your IP address. Then enter, ipconfig/renew and hit Enter to renew an address from the DI-704. The IP address, subnet mask, and default gateway information will be returned with this command. Notice in this example that the IP address is 192.168.0.104 and that the default gateway is 192.168.0.1. This information verifies the network adapter is properly configured and the computer is communicating with the DI-704. For Windows NT: Click Start>Run and enter command, then click OK. At the DOS prompt, enter ipconfig/release and hit the Enter key to release your IP address. Then enter ipconfig/renew and hit Enter to renew an IP address from the DI-704. Note: If you receive any error messages at this point, you may either have a problem with the functionality of your network card, or it may not be configured to obtain an address automatically in the TCP/IP properties. Step 4 Open your browser and type 192.168.0.1 in the Address window, then hit the Enter key. You do not need to type http://, only the IP address of the DI-704. This will connect you to the web configuration utility that lets you manage the DI-704. You are not on the Internet at this point. Type admin for the System Password, then click the Login button to login. Step 5 Select the Setup menu option from the bottom of the screen. Make sure the WAN type is set to Dynamic. Check box to enable Renew IP forever. If the WAN configuration is not set to Dynamic, click the Change button and select Dynamic. Next, click the Save button and then the Reboot button on the bottom of the screen. Click OK when prompted to Reboot right now? Step 6 Next, we need to do something called cloning the MAC address. This will insure that you can connect through your modem in the event that the MAC address, or physical address, of your network card has been registered with your ISP. Cloning the MAC copies the MAC address of your ethernet card to the WAN port of the DI-704. In other words, it will appear to your ISP will that it is your computer connected to the modem, not the gateway. That is why it is necessary to configure the DI-704 from the same computer tha
Top Paxar Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
