The heater heats up, the blower comes on for a minute then goes off, and continues to cycle like this
Good Morning, So, you say the heater does heat up, the fan will cycle on and shuts back down in a minute, and continues to cycle this way. A few things that will cause this. But let me ask this first, does the burners stay on through this short cycling of fan? Let me know if we don't solve it before that. I don't know if you're t-stat is programmable or a mechanical? Anyway, you have what they call a heat anticipator on stats which will cycle unit on and off like this if they have burned out. If it is a mechanical (mercury switch) type, pull the cover and you will see a small dial with numbers and a arrow on it. Set it to .4 and if its programmable, you will have to go into the program to do this. Normally it is set at factory to .4 amps and the setting varies with the amps on the gas valve as they should match. I assume you have been there for sometime and this problem has just started.I wish I knew if the burners were shutting off when the fan cycles off? This would be helpful. If the burners stay on because the fan is only off for a short time, the high Limit switch is good, because when the burners are on, and the fan comes on and shuts off and stays off, the unit will open the contacts on the high limit and shut burners off for safety. I would say that the combination fan control is sticking or failing causing your fan to short cycle. Only, if this is an older furnace though. If it is a newer one with the electronic pilot ignitor, the main control board is you're problem and will need R & Ring. Please get back to me and give me the information I have mentioned, as name, model #, serial #, and age or if it is eletronic pilot or a standing pilot(on all the time) this will help to solve this. Also, what stat you have.Try the things I mentioned, but please get back to me so we can solve you're problem. Thank you, and Sincerely,
Shastalaker7
