Hi. You can unlock your T-Mobile network locked LG TG800 safer and easier using unlock code. You can get6 the unlock code for a LG TG800 from SimpleUnlocking.com at affordable cost.
1 - Switch ON your LG TG800 Chocolate with its ORIGINAL SIM Card.
2 - Then compose : 2945#*7101#.
3 - In the menu that appears go to "Settings".
4 - Then select "Security".
5 - To finish select "SIM Lock" and Enter the Unlock Code.
ow to Enter Unlock Codes on LG KB770:
Insert an original simcard and turn phone on
Enter sim PIN if required
Enter 2945*#770#
From the menu that pops up select "SIM unlock"
Enter unlock code you received and press OK
The phone will then reboot and the unlock is complete
How to enter Unlock Codes to LG GB250 & GB220
Power on your phone without SIM card
Enter 2945#*505#
Enter unlock code and press OK
How to Enter Unlock Codes on LG GT505:
Enter 2945#*505#
How to Enter Unlock Codes on LG KP100:
1) Insert a not allowed SIM card
2) Press the unlock button
3) Enter the code
OR
1. Insert allowed SIM.
2. Booting (Request PIN Code, PIN Code enable)
3. In Idle Screen, Input the hidden number (2945#*20001#)
4. Input the number (above), go back to the idle screen
5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate:
6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:".
7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code
How to Enter Unlock Codes on LG KF390 and KF390q:
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Reinsert the unlock code
7) Select OK. Done!
How to Enter Unlock Codes on LG Prada (e.g KE850, etc):
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
1. Insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990#
3. A menu will pop up, select sim unlock:
4. Another menu will appear, select Network lock. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
How to Enter Unlock Codes on LG KG245 (Vodafone Australia):
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Optional Step: If the SIM card has a PIN, enter your PIN number
4. Wait for the phone to power up then enter 2945#*7101#
5. Select Menu , then go to Settings > Security > SIM Lock > Network
6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Enter Unlock Codes on LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Enter Unlock Codes on LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM Unlock code
5. Select "OK" - the handset is now successfully unlocked
How to Enter Unlock Codes on LG U8150:
1. Switch ON your phone with a not allowed SIM card.
2. Compose: 277634#*#.
3. Go to menu "SIM Lock".
4. Enter the unlock code
How to Enter Unlock Codes on LG INCITE CT810
Power on phone with original SIM card
Type 2945#*810#
In the menu that appears select Sim unlock
Enter supplied unlock code
Your phone is unlocked
How to Enter Unlock Codes on LG F2250
Power on phone with Orange SIM card inserted
While in the Start menu type 2945#*3311#
Return to the startup screen
Press Menu key
Select Settings > Security
This is a CDMA phone, which mean that it can only be use with Verizon or Sprint, or any other company that does not require the use of a SIM card.
This means that you need to take it over to Verizon and tell them that you want it unlock so that it can be use with any other CDMA carrier. It won't work on AT&T or T-Mobile, or any GSM carrier.
Tmobile and Verizon use 2 totally different cell serrvices. Verizon is a CDMA signal and Tmobile uses a sim card based GSM service. Those 2 are not cross compatible.
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.i hope this will help you :)Good Luck.
yes you can buy a mobile unlock you can do that online or check wih any mobile store in your area....to know if the phone you are purchasing is unlock , just do not take the CSR's work for it carry your sim-card with you and try it in the phone you will be buying.
