Hi. You can unlock your T-Mobile network locked LG TG800 safer and easier using unlock code. You can get6 the unlock code for a LG TG800 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your LG TG800 Chocolate with its ORIGINAL SIM Card.
2 - Then compose : 2945#*7101#.
3 - In the menu that appears go to "Settings".
4 - Then select "Security".
5 - To finish select "SIM Lock" and Enter the Unlock Code.
SOURCE: LG TG800 Unlock code
hi - yes we can get your unlock code -
http://horizonwirelessonline.com
use discount code DIGG10 for extra 10% off
SOURCE: Unlock for LG TG-800 (similar to KG800)
To Unlock KG800/LG
1. Insert sim from the network that it is locked to.
2. Turn on phone
3. On home Screen, Slide up phone
4. Type 2945#*#
5. ENG. Mode menu should appear
6. Go Down to Factory Reset Select it, may take a few minutes to reset!!!!!
7. This will reset the phone back to before the Phone was locked to a network
8. The phone will automaticaly Restart(Note The Network Logo At start up will not change)
9. Now insert Any simcard(Not tested with 3 sims)and the phone should turn on normaly
10. The phone is now unlocked and you can customise the setting as you like.
SOURCE: Unlock code for LG Chocolate TG800
we're very sorry but you 're requesting an expensive one... go to your nearest center and they will unlock your fone...
