I am looking for a JBL 4311 WX-A speaker internal wiring schematic? More specifically, the internal wire color codes that go to each original driver's positive and negative terminals. The factory wire color code inside enclosure is as follows: Woofer = green and green/blk stripe; Midrange = white and white/blk stripe; Tweeter = yellow and yellow/blk stripe. Which wire color code goes to which terminal on each respective driver?
The conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
