Section 01-09: Mirrors, Rear View
1999 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 06/25/1998
Mirror, Power-Outside Rear View
Removal
Disconnect battery ground cable (14301).
Remove front door trim panel (23942). Refer to Section 01-05.
Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
Remove two screws from cover assembly.
Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item
Part Number
Description
Outside Rear View Mirror
N621906-S36
Nut (3 Req'd)
F8DB-17D699-
AAW
Cover Assembly Rear Substrate-LH
F8DB-17D698-
AAW
Cover Assembly Rear Substrate-RH
N808968
Screw
5
F8DB-18B984-
AAW
Speaker Grille-Standard (No Badge)-LH
5
F8DB-18985-
AAW
Speaker Grille-Standard (No Badge)-RH
5
F8DB-18K901-
BAW
Speaker Grille-Mach-LH
5
F8DB-18978-
BAW
Speaker Grille-Mach-RH
5
F8DB-238A35-
AAW
Speaker Grille-Blank (No Speaker)-LH
5
F8DB-238A34-
AAW
Speaker Grille-Blank (No Speaker)-RH
A
Tighten to 6-8 Nm (54-70 lb-in)
Trim Panel, Door
Front
Removal
Remove cover behind inside door handle.
Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
Remove three screws retaining front door trim panel to front door.
NOTE: Do not attempt to remove more than one pushpin at a time.
Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
Follow removal procedure in reverse order.
Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
I got it! It's not the clips, but the speaker was glued to the door, so I had to use the screw driver to pull it off. Thank You!
