Replace fuel tank seals VW T25
Dropping the fuel tank is rather involved. Beyond this sort of Q&A format.
I suggest you get a Bently Workshop Manual and a seal kit from gowesty.com or similar.
Also plan on replacing fuel hoses and a new filter would be a good idea.
One word of caution. The plastic overflow tanks in each wheel well have nipples for the fuel lines that become quite fragile so BE CAREFUL! The tanks are not available new.
SOURCE: Can I replace the oil cooler seals on 1980 Vanagon w/ engine in?
Hi!
I hate to rub salt in your wounds but after all your effort the time spent you could have the engine back in by now.
All the tin ware needs to be lifted well clear as you know the oil cooler is upright in the path of the Rotor/fan, this also needs to be raised well clear as the cooler needs to be taken off completely, you will want to clean surfaces and internals won't you?
So all shrouds to bodywork off,(Engine bay) throttle cable disconnected, clutch cable disconnected your generator wires off and finally fuel pipe. 4 bolts on gearbox bell housing and slide engine out or down for clearance on trolley jack.
All the above relates to a TypeII Split or bay window with stock engine, Not suitcase or injection.
Good Luck!
Please remember to appraise my FREE efforts by pressing the Blue button? Thank You!
Paul 'W' U.K.
SOURCE: I have a T25 Transporter 1990 ,front wipers won`t
It sounds like the park switch inside the wiper motor has failed or a bad contact. If you can get to the motor, remove the plate/cover and you should see a micro switch, check it for broken wires or clean contacts. If you dont feel comfortable doing this, then take the car to an auto electrician, he should be able to sort it.
Hope this helps
