You have connected the LAN cable from the modem into the correct Internet port on the router.
This error message you got could mean you have a faulty cable. To test the cable, connect the cable from the modem to your computer's LAN port to see if it connects to the Internet. If not, the cable is faulty and needs to be replaced.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
We have a Touchtone Telephony modem in which the cable comes out of that into the internet port on the new wireless. This is the same way the old regular router was hooked up.
Thanks for your help but for some reason it would not work and it has been returned.
Is the LAN cable from the DSL or cable modem connected to the Linksys LAN port or the WAN/Internet port?
