Ace Hardware PowerGlide 18V Trigger Cordless Drill/Driver Logo
Posted on Feb 09, 2010
MY CHARGER DOESN'T WORK AT ALL WILL THE BATTERY FIT IN ANY OTHER MANUFACTOR'S CHARGER?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
209
Points
Give it toa person who can fix it
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 • Cell Phones
Replace battery in GARMIN nuvi 1450
it's hard to find the cpecific model that would fit the device, ant this device doesn't even has a user replacable battery. i suggest you keep it on charger while in your car or if it still under warranty to get it fixed/replaced
4helpful
2answers
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
3helpful
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 • Cell Phones
1helpful
Laptop won't turn on
It may very well be a bad jack but it also could be a bad battery that is not retaining charge. Yes, a bad battery will cause many laptops not to turn on.
1- how does the charger jack fit; is it loose or wiggle when pluged in? or does it fit snugly with no movement when plugged in? If the charger no longer fits snuggly or moves a lot when plugged in, it may very well be a bad dc jack. Not a task for a DIYer but well worth having fixed.
2- Try removing the battery and see it powers on the charger only. Some laptops will not work without a battery and some will. If this is a Gateway, it probably will work without a battery.
Car charger
I HAVE A CAR CHARGER FOR THIS UNIT IF INTERESTED E-MAIL ME AT [email protected]
Top Ace Hardware Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you an Ace Hardware Drill Expert? Answer questions, earn points and help others
