20 Most Recent
Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack Questions & Answers
My cobra microtalk cxt450 will
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Cobra microtalk LI 7500 WX
fyi my Cobra microTALK LI7500-WX came out of the box with one of the radios slightly off frequency, limiting range to about 100 ft. I was able to use a counter to fix it. The freq adjust is under the front faceplate that covers and protects the LCD screen, pry it off to expose one tuning pot.
What if your walkie talkie
If the antenna is exposed that radio will get inductance, normally most walkie talkie antennas are
composed of a coil of bare wire, a shield around the wire to keep out inductance or noise, and
the outer layer to keep it together and protected. if the metal is exposed you can cover the area
with a piece of aluminum foil and wrap it with black tape or electrical rubber tape sold at most
hardware stores or an electrical supplier. or you can go and by another antenna. good luck!
How do i turn off the bleep?
There are three functions on that unit that cause some kind of beep.
one in the tone when you first turn telling you it's working.
Then there is the one that cobra refers to as the 'Talk Confirmation Tone' telling the other person it's ok to talk.
The third will only be sent if you do it intentionally, that's the call alert tone.
You have absolutely no way to disable those first two functions as they are hard coded into the handheld memory.
These are made to be ......... proof and are just a marginal step forward in technology from the tin cans and string.
To charge
Radio shack sells "splitters" that have 2 cigarette lighter outlets with one plug. About your only option.
