Computers & Internet Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot Phoenix Bios Setup Utility password. received this message Service Num:BW47X21 can you help bypass password This is for a Laptop computer Dell Inspiron 5100
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Feb 07, 2010
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405409
Points
12062
You can bypass the password, but it does require contacting Dell to get the information:
http://www.fixya.com/support/r3656360-dell_portable_computer_bios_hard_drive
Whaat is phoenix bios setup utilitiie and whats the password
You may be able to access the bios using one of these backdoor passwords for the phoenix bios
BIOS
CMOS
phoenix
PHOENIX
Or you may be able to reset the bio password using this utility.
http://www.cgsecurity.org/wiki/CmosPwd
WHAT IS PHOENIX TRUSTEDCORE (tm) setup utility mean?
Some hardware or software has upset the serial number used by the BIOS (phoenix) to guarantee that the computer is the same as it was when it was bought. This is the trusted bit.
The setup utility needs to recalculate this number to include the new equipment, consult your laptop manufacturer Toshiba, via the support function.
What is the Phoenix Trustedcore(tm) Setup utility password
If it's a BIOS password, ask the person that put it in. OR, contact the the Laptop Manufacturer for a one-time BIOS password.
I can't get into my acre aspire one laptop it's
http://dogber1.blogspot.com/2009/05/table-of-reverse-engineered-bios.html
http://www.biosman.com/bios-password.htm
http://www.ehow.com/how_5268844_reset-phoenix-bios-password.html
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    8helpful
    2answers
    Sir, I'm very happy to read from you and to know how far you are doing in computer. I'm having problems with my Toshiba Laptop dynabook satellite 1860 . I have being using the my compuetr with...
    Using a Backdoor BIOS Password
    Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
    AMI Backdoor BIOS Passwords
    Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
    Award Backdoor BIOS Passwords
    One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
    Phoenix Backdoor BIOS Passwords
    Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
    Backdoor BIOS Passwords from Other Manufacturers
    Reported BIOS backdoor passwords for other manufacturers include:
    Manufacturer BIOS Password
    VOBIS & IBM merlin
    Dell Dell
    Biostar Biostar
    Compaq Compaq
    Enox xo11nE
    Epox central
    Freetech Posterie
    IWill iwill
    Jetway spooml
    Packard Bell bell9
    QDI QDI
    Siemens SKY_FOX
    SOYO SY_MB
    TMC BIGO
    Toshiba Toshiba
    Or
    Resetting a Toshiba BIOS Password
    Download (Keydisk) http://www.cgsecurity.org/keydisk.exe will reset the BIOS password on Toshiba laptops.
    Can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
    Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
    Forgot the password for phoenixbios setup
    You need to contact your pc manufacturer.
    Tell them to provide you with the steps to remove and reseat the CMOS battery.
    Then remove and reseat the CMOS battery which holds the BIOS password.
    This step will remove the password.
    Issue is resolved :)
    2helpful
    Password entry denial
    use the recovery disc go into bios under the word boot set cd dvd drive as first insert recovery disc restart comp follow instructions
    1helpful
    3answers
    How do i bypass the primary drive lock password
    On the mainboard near the coin battery you'll find a jumper. take it off and reboot. Replace it and reboot again. that works sometimes. If not you can go to the motherboards' BIOS like Phoenix and they have backdoors built in. Read on:
    Backdoor passwords Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
    WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
    Award BIOS backdoor passwords:
    [TABLE]
    AMI BIOS backdoor passwords:
    [TABLE]
    PHOENIX BIOS backdoor passwords:
    phoenix, PHOENIX, CMOS, BIOS
    MISC. COMMON PASSWORDS
    [TABLE]
    Good luck...hope this helps...
    Grand Canyon Tech
    Grand Canyon Tech
