Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
