1996 Chevrolet Lumina Mini Logo
Posted on Feb 04, 2010
1996 Chevy Lumina wont start. Relay fuse on passenger side under hood clicks. tried replacing it, wont start. but if you wait 8 hours, a day or two, and try, it fires fine??? The only time it wont run is when you turn the key and hear the fuse clicking. 3.1L V6
Richard Bohr
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2015
Richard Bohr
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
941
Points
Same problem. It will turn over but not start if the fuel pump relay clicks.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Feb 05, 2010
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
21507
Points
41
Could be several things....but i need more information. When it doesnt start, does it crank or when u turn the nothing at happens other than the relay?
1helpful
2answers
Headlight fuse panel location on 96 Chevy lumina car
Fuses are located on the passenger side of vehicle. Open door and look at the end of dash. Another fuse panel is located under the hood on the passenger side of the vehicle.
1996 Ford Explorer Radio Not Working
the fuse for the radio is not under the hood its in the passenger compartment on the drivers side
What are some symptoms of Fuel Pump going out in a 2001 Chevy Lumina??
The pump would not be providing fuel to the injectors.
The pump relay could be making the noise. The relay is in the fuse box on the passenger side of the radiator.
Fuel pump went bad had it replaced along with the fuel filter car started yesterday but now won't start cannot locate where the fuse would be (1995 chevy lumina) any ideas?
There are 3 , 1st and second are under the hood on both sides where you would normaly see the batt and 3rd on the passenger side, side of the dash, need to open door for access
Fuel pump wont come on.Was wondering where the fuel pump relay switch is on the 1990 chevy Lumina
If it is the same as my 1991 lumina it will be mounted to the left strut tower under the hood. There should be a fuse and a relay.
1helpful
2answers
Where is the heater motor in a 96 chevy cavalier?
The heater blower motor is connected to the heater core housing passenger side, under the hood, on the firewall. It may be a very involved replacement with specific steps required to change without breaking a different component. Check it out - if there's a bunch of stuff ( like a/c hoses,drier,evaporator,etc.) in front , you may want to take it to your local shop for replacement. If it's not working, first check the fusees and or relay to make sure that's not the problem. Fuses should be under the dash in the fuse panel - if it has a relay that should be under the hood, passenger side, rectangular black box. The covers for both panel and box should have a diagram of which fuse / relay is what.
I have a 1996 chevy lumina. the motor wont turn
You need to check for power at the purple wire going to the solonoid while key is in the start position, if no juice then check starter relay-under hood- fuse ,and ignition switch
My cooling fans are not coming on.the fuse is good.where is the relay switch located for cooling fan? i think it might be bad.thanks.
The relay for your cooling fan is located Under hood, passenger side, front side of wheel well, mounted in relay panel. I would also recommend testing or inspecting the coolant temperature sensor as well. it is located Under hood, passenger side, upper engine area, above water pump, mounted in intake manifold
Please rate and have a great day:)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
