Sony Walkman Bean NW-E307 MP3 Player Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Erase song from device - Sony Walkman Bean NW-E307 MP3 Player
Anonymous
Level 3:
Guru:
  • Master 513 Answers
  • Posted on Apr 19, 2010
Anonymous
Master
Level 3:
Guru:
Answers
513
Questions
0
Helped
214796
Points
1589
If you have a song that will NOT erase, remove all the songs you have on the unit you wish to save. Disconnect from the computer and Format the unit using the built in menu.
Reconnect to the computer and reload all your songs.
The unit should now be 'pristine'.
An occasional format of an MP3 player is always a good idea. It fixes all kinds of weird problems. Once every six months should be often enough.
3helpful
5answers
How do i delete songs of my i pod
The first way is uncheck the songs you want to delete on iTunes and then sync iTunes with ipod again, then the songs you want to delete will lose from iPod.
The second way is use leawo iTransfer to delete songs from iPod, the way is connect iPod to leawo iTransfer, then right click on the music you want to delete from iPod on leawo iTransfer to choose "Delete", then the music will be deleted soon. However, this tool can only work on Windows computer.
When I go to try and delete songs from my sansa e250, windows media says that there are no songs on the device...however, the device says there are 395 songs on it, and they show up on the device. How do I...
are you trying to delete the songs from a different computer than you put them on ? i had this problem when i used my roomates computer to put some songs on my old sandisc when i tried to erase them from my computer they wouldnt show up but i had no room left on the mp3 so i ended up haveing to erase them on the same computer as i had downloaded them on
2helpful
5answers
Deleting songs from iphone
you should be able to go into itunes and delete the songs, then sync your iphone again. If that doesn't help then I would go into the apple store and see why not. you can also just call apple for support for free if you are an at&t subscriber good luck
Erasing songs, unknown amount of storage.
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..And its depend on the size of the songs...it could take about 50 music..once again it depends on the size of the music...
let me know if that doenst work for you...
Hope this helps
Erasing songs
You can try formatting it or erasing all the songs manually - just plug your player in, go to 'my computer,' and click on your device. Then you can erase your songs manually. Hope this helps!
HOW ERASE
You can delete the songs by highlighting all of them in Windows Media Player, or you can go to Start --> All Programs --> Philips Digital Audio Player or Philips Device Manager --> open Philips Device Manager, and select "Repair" - this will have the side effect of erasing all of your songs safely.
-Tha Mp3 Doctor
Sansa having problem with sync
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Songs dnt show on my device.
Go ahead and do this, in case the DB is corrupted:
Doubling songs
Reformat the player and start from scratch
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
