Nobo heater we have a series 14 nobo heater and we cant turn it off auto. We have tried to reset them but this still doesnt work. The lights are on to show it is working but we just need to turn the auto function off somehow
The nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Posted on Oct 20, 2010
    New Friend:
You need to replace the rechargable button cell on the control panel.
See here: http://www.aliexpress.com/item/4-pcs-lot-1-2v-80mAh-NI-MH-rechargeable-battery-button-cell-coin-cell-battery-pack/32457786723.html?spm=2114.01010208.3.2.tvbl1j&ws_ab_test=searchweb201556_0,searchweb201602_1_10057_10056_10055_10049_10059_10058_10017_405_404_106_10040_105_104_10060_103_102,searchweb201603_2&btsid=74024965-1383-42be-86c9-970f2179d8ec
Posted on Jul 25, 2016
Heater turned on. Why is there no heat?
Check the heater tap turns on and there is good water flow through the hoses and heater core ,check that the water temp is at least 85 deg.cel.. could also be the baffle in the heater core broken off.
Dec 19, 2015 | 2003 Saturn L-Series L300
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 08, 2014 | Hardware & Accessories
Nobo Heater - Power not constant
You do know that these kinds of heaters "cycle".?? They turn on and off, as a control regulator (thermostat) tells them to. You should have an adjustment that will control how frequently it cycles on and off... You should also have some kind of switch that shuts the heater down if it gets tipped over. However, I tend to assume you know most of this.. If it was simply "cycling", though, I'd think that there would still be some light on full-time to show it really was plugged in and working... So, if I had to bet my money, I'd bet that there's some built in safety switch inside that heats up and kicks the whole thing off quite soon after you start it going. I'd guess that by unplugging it, it eventually resets itself so that you can try it all over again. It could be one of those cases where it might be easier and cheaper to junk it and buy a new one.
Nov 14, 2013 | Heating & Cooling
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Oct 16, 2010 | Heating & Cooling
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
SHARP AL-2040CS Drum reset code
c - auto - c - auto - (machine is off) 24 - start - 07 - start (000 blink) - 4x botton c . Finish ok.
Apr 28, 2009 | Sharp AL 1631 Copier
Error 7 , the copier seems to be stuck
Give this a try, Just 7 is not normal. Is there a letter appearing first?
But try this procedure.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Apr 08, 2008 | Xerox WorkCentre XD130DF Laser Printer
Flashing 4-H error message
try this reset procedure. Most likely this will work.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 29, 2007 | Sharp AL 1631 Copier
Heating & Cooling Logo
2,043 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
