Question about Hardware & Accessories
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
My nobo timer 8430018 has broken and i have a new one to fit but i cant get the instructions unless i buy one from the dealer.
Posted by theo nicholaou on
  • theo nicholaou Oct 13, 2014
    There is a junction box with 6 points of entry and there are three wires within the timer that go into 2 of them. What I don't know is which of the 3 leads from the radiator go into which point of the junction box. These obviously mary up with the load, earth etc. To confuse things, there is doubling up in one hole and some sort of interlinking diode I think you call it. More like an aircraft than a radiator timer! Please help as NASA wont answer.
Gene Haynes
  • Hardware & A... Master
  • 5,391 Answers
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 10, 2014
  • theo nicholaou Oct 12, 2014
    This can be seen on the credaheating.co.uk website which is the owner of logo and indeed to sell replacement timers with this model number albeit through a distributor. I was told I would not be given swap over instillatyion instructions unless I bought a replacement in which case the info was contained with in the box.
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Posted on Dec 10, 2008
Anonymous
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
Anonymous
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
Anonymous
SOURCE: Need instructions for Aube by Honeywell 7-day
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
Posted on Feb 19, 2010
Anonymous
  • 127 Answers
SOURCE: Need user instructions for a Grasslin iht d120
Took a little hunting but managed to find it for you.
Here's the link to the manual including programming instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/km2st-2d%20-%20english.ashx
Have a great day
Jim
Posted on Dec 29, 2010
Star waffle baker can the touch panel be re set
no the touch panel cant be reset these timers do tend to go after a certain amount of use it is not worth replacing as it can be as expensive to get the parts and fit them it would work out cheaper to buy a new unit as repairing the old unit you will come across more problems as after a certain age they tend to start going wrong so i would advise you to buy a new unit as after you have brought the spares and a soldering gun and some solder you are looking at about the same price a oyu would tto buy a new unit sorry i couldnt be any more help to you but i would advise to buy new one hope this is some help..........................................
Nov 17, 2007 | Kitchen Appliances - Others
Nobo Heater - Power not constant
You do know that these kinds of heaters "cycle".?? They turn on and off, as a control regulator (thermostat) tells them to. You should have an adjustment that will control how frequently it cycles on and off... You should also have some kind of switch that shuts the heater down if it gets tipped over. However, I tend to assume you know most of this.. If it was simply "cycling", though, I'd think that there would still be some light on full-time to show it really was plugged in and working... So, if I had to bet my money, I'd bet that there's some built in safety switch inside that heats up and kicks the whole thing off quite soon after you start it going. I'd guess that by unplugging it, it eventually resets itself so that you can try it all over again. It could be one of those cases where it might be easier and cheaper to junk it and buy a new one.
Nov 14, 2013 | Heating & Cooling
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
I cannot program the "Off" time on my GE smart digital timer model 15071
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
GE 15071/ manufactured Tork SS720
Reset timer, and try again.
Push and hold reset button with paper clip or toothpick for 3-5 seconds.
Buy new timer at Home Depot and return defect with new receipt.
Otherwise instruction manual is straightforward, and would not accept ON time unless wired correctly.
Mar 19, 2013 | Hardware & Accessories
I have a utilitec self adjusting wall timer #0192773 that stopped functioning. The led display is blank. I tried to re-set per the instructions, but nothing. I've confirmed power to the timer. Does this...
If resetting timer does not restore functionality, and timer has power, and you checked that LIGHT BULB is good, then timer has gone bad.
To double-check circuit, replace timer with ordinary on-off switch and see if it works.
Warranty: buy new 0192773 timer at Lowes, and return broken one inside new package.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Apr 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I can not reset my Timex timer . The timer stopped working after a month and the instructions to not help in programing these timers
The instructions will help quite a lot right now:
1) Typical Timex manual says to re-set timer, press MODE and PROG buttons together.
Compare this information with your instructions.
2) Look on instruction sheet for timer model number, and then add a comment with your model number so I can identify timer manual and possibly post answer that fits your product.
3) Look on instruction sheet for company information.
Timex timers come with standard 1 year limited warranty:
Following phone might work: 1-800-919-3101
4) Scan your instruction sheet into jpg format and then add a comment with link to that jpg, then I can give you best answer for that specific timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) Buy another timer, and return broken timer in new package.
6) Use circuit analyzer to test outlet for line noise and ground fault that affect timer electronics.
7) Buy another brand of timer altogether:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | Timex EASY TO SET TIMER BY TIMEX
Have a similar question to the others asked about the GE Smart Digital Timer 7 day timer model 15086. I originally got the wires connected but the exterior lights remained in on position. The manual...
Wiring instructions and on-line manual appear on following link.
I have tested this timer, but I'm not there to test it out for you.
Let me offer a troubleshoot list how I would start.
1) Switch located behind timer door that says OFF-TIMER. Make sure it is set to Timer.
2) 4 square buttons located behind timer door that sit in each corner. These are override buttons, and should turn lights on-off. Push each one separately.
3) Check wiring against instructions shown on link above. This timer will not operate unless wired correctly.
4) Ground wire broken off? Each cable that enters a box can be pulled a bit further so maybe you can grab some of the ground.
The ground is not critical for timer operation -UNLESS- you are using it to power electronic clock inside timer.
Normally white neutral wire is used for clock electronics, as described in wiring instructions.
5) Conflicts in programming. If 7-day programming has conflicting days or hours, timer will not operate as expected.
Check programming.
6) Reset timer and start over.
7) I test timers, and some arrive defective. GE makes a good timer, manufacturing timers for many decades: 15086 is sold at Home Depot. Buy another one and take back defective one.
Add a comment for more free help.
Mar 10, 2011 | GE Electrical Supplies
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Oct 16, 2010 | Heating & Cooling
Nobo heater
the nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Feb 20, 2008 | Heating & Cooling
Hardware & Accessories Logo
1,014 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
