turning the screw way out makes the mixture lean, so the problem must be the carb is too rich. check all the jets were installed correctly when the carb was cleaned make sure the carb float bowl is not flooding. Check the fuel tap is working correctly. make certain the airfilter is clean. check the engine has correct amount of clean oil( not fuel contaminated)
it sounds to me like you have a faulty terminal, check voltage reading to the relay from battery pos terminal, now push and hold button and recheck on same terminal, if it stays at around 12volts check terminal on other side of relay it this is lower significantly than first side replace again with new relay. of both terminals voltage drops you have faulty battery.
