Bethesda Softworks Fallout 3 for Xbox 360 Logo
Posted on Jan 27, 2010
Fallout 3 disc reading/load issues
I start my 360 and pop in fallout 3. everything works well until I try to load my game even when starting a new game and trying to save the game will completely stop and say disc reading error, but the game loads.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
868
Points
6
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
It thinks some game discs are DVDs
FIRST GET A HAMMER THEN BANG THAT **** 17 TIMES THEN GO BUY YOURSELF A OTHER ONE.
1helpful
Fallout 3 freezing
Well your disc is officially garbage because it's for sure scratched. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Freezes randomly constantly
your about to get the red ring of death
Downloads for fallout 3
You must finish the original game and type in the code in the reactor. and wake up in the new game
When im playing fallout 3 after a while the screen go grey and freezes or it says disk is unreadable and when i look at the disk it looks fine its not damaged or dirty or even scrached its a new disk
SOME DISC ARE PARTAILLY MELTED WHEN YOU BUY THEM OR GET TO HOT AFTER YOU BUY THEM. IN ALL CASES TRY ANOTHER DISC AS SOON AS THIS HAPPENS TO ENSURE THE LAZER IS READING PROPERLY. IF SO ITS TIME FOR DISC REPLACMENT. YOULL FIND IT AT XBOX.COM IN THE SUPPORT SECTION. HAPPY GAMING AND HOPE TO SEE YOU IN GEARS OF WAR TWO..
Unreadible Disk as soon as I put the disk in.
do other games work? if not your magnet in your xbox console disk drive may be defective and i would suggest returning it to Microsoft to have them look at it. If other games do work your fallout 3 disk may be severely scratched or the magnetic strip on it may have gotten demagnetized or otherwise damaged and will most likely need to be replaced...sorry
The right analog stick does'nt work with fallout 3
if its glitched you most likey wont be able to get it to work if not try renting fallout 3 and see if it works with the rented one otherwise youll have to delete youre saved game and start over i had to do that with nascar 09 because it glitched me and only when i started over did things work correctly
6helpful
5answers
Fallout 3 Freezing Problems???
Fallout 3 freezing is an unfortunately common problem. A lot of people have reported that clearing the game cache on your 360 will fix it, so that's what I would suggest you try first.
To do this:
  1. start up your 360, then take out the Fallout 3 game disc.
  2. Hold down the A button on the Player 1 controller
  3. Put Fallout 3 in your 360, then load the game
If this doesn't fix it, the next thing you could try is to clear the system cache. This will clear the entire cache for your 360, including the automatic updates (though downloaded content, save files, and user dats will be untouched).
To do this:
  1. Navigate to System > Memory
  2. Highlight the hard disk in the list and press Y
  3. Press X, X, LB, RB, X, X
If done right, you should see a message asking, "perform system maintenance?" Proceed with this, and it will clear all the cache data out and revert Fallout 3 back to version 1.0 (it should ask you to update once you load the game)
Hope this helps - I've had my share of frustration with Fallout 3 glitches.
-Nick F.
3helpful
2answers
Frozen Fallout 3
I would download the game to the hard drive and it freezes a lot because its on open world rgp so it has to load a lot.. But if you download Fall Out 3 to your hard drive it will increase load times and reduce freezing.
Top Bethesda Softworks Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Bethesda Softworks Video Game Console and Game Expert? Answer questions, earn points and help others
