The keyboard must be damaged for having that problems or this could happen also because a bad configurataion also u can try cleaning the keybord in a very soft way this could also be the problem
Yikes, i've had that problem before, just for kicks, try plugging that keyboard into another computer and see if it types properly. If it does type properly then we know the keyboard is good and its and issue with the Operating system on your original computer.
If the keyboard still types double and other keys not working on the 2nd computer then we know the keyboard is bad.
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt
Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
Youll notice the password is gone.
if this fails try typing
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of tenhope this helps
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
DEBUG
o 70 2e
o 71 ff
Q
your BIOS Setup.
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
DEBUG
o 70 2e
o 71 ff
Q
your BIOS Setup.
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of tenhope this helps
some manufacturers use there own name as the bios password
try phoenix is this fails
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
DEBUG
o 70 2e
o 71 ff
Q
your BIOS Setup.
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Bored?
