Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
I have the Craig CDV329 and have had it for nearly a year. It isn't played very often, and until now has played well. Just recently is states "No Disc" and upon subsequent loadings, "Unknown Disc". Should I junk it?
Thanks eddie [email protected]
I hooked my cvd-329 to the TV and inserted dvd it reads and then an error msg appears and show up as no disc. It also starts "rolling" and I can not stop it. I used a cleaning disc but no help. I changed Disc's but no help.
