You say you have used ethanol. I don't know if you also putit in the gas tank as well as the carb. However, regular of the shelf ethanol from a paint store is not the ethanol to use. hat ethanol is hydrated, ( has water in it ). You need to use anhydrous ethanol or gaslineanti freeze. asfar as what to put down the carb, you should be using quick start. ( Tha is ether and is very flamable!!!! ) only spray that while turning the engine over. To check what that clear fluid is in the tank somehow take a sample of it and try to disolve table salt in it. If is it oil the salt will not disolve. If it is wate it will. Please don't just put the salt anywhere near the carb. or the gas tank.
I suspect it is water because oil and gas mix. water and gas do not. The anhyrous ethanol in the tank will adsorb the residual water and mix with the gas and burn off in the cylinders.
Good Luck!
