1998 GMC Sierra Logo
Anonymous Posted on Jan 14, 2010
Replacing interior door handles on 98 Sierra
I tried to follow the instructions on how to replace the interior door handle on a 98 GMC Sierra, got all the way to getting door panel free from inner shell, but trim around the handle assembly holds it to the door...not sure what to do, do not want to break that trim...have assemblies ready but am stuck...
  • Anonymous Jan 14, 2010
    guess i'm not seeing what you are talking about, got both panels loose but still held on by trim around door handle assembly....
    I appreciate the help a ton, but for the life of me see no screw......looks easy..... ain't though....
    if you can describe where i can find this screw i'd appreciate it....once again thanks for the help...yes it is a 98
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
5610
Points
30
On the inside of the trim peice take a flathead screwdriver and gently work around the inside of the trim peice and if you find the right spots were the clips are it will just pop off.
Anonymous
Level 3:
President:
  • Master 1,244 Answers
  • Posted on Jan 14, 2010
Anonymous
Master
Level 3:
President:
Answers
1244
Questions
0
Helped
410333
Points
4051
Theres what they call horseshoe spring clips on the back side of the handles they make a special tool that pushes them off! but if you got a small piece of stiff wire take a pair of needle nose pliers and make a short!! gental hook on the end and push the door panel back far enough to see the clip and hook into it and pull straight out!
    98? model has a screw in the area the door handles are in one screw and when you remove it the plastic piece around the handle your caling the trim comes off
    you know the little plastic cup that goes around the door handle? looks like part of the panel?? in right!! there!!!
1helpful
2answers
How do I replace inside door handle passenger side on a 2011 GMC Terrain?
Search Results
    How To Install Replace Inside Door Handle Chevy Equinox ...
    ? 9:02
    https://www.youtube.com/watch?v=cY6asyM2R6g
    Feb 2, 2012 - Uploaded by 1A Auto Parts
    How To Install Replace Inside Door Handle Chevy Equinox 05-09 1AAuto.com .... found your tutorial on fixing my driver's side door handle for my 2006 Equinox. .... Door Handles Chevy Equinox 2010 2011 2012 GMC Terrain ...
    How To Install Replace Inside Door Handle 2007-13 ...
    ? 9:05
    https://www.youtube.com/watch?v=QonKLwhk2CE
    Apr 2, 2015 - Uploaded by 1A Auto Parts
    http://www.1aauto.com/interior-door-handle-driver-side-front/i/1adhi00417 1A Auto shows you how to repair, install, fix,change or replace a broken or snappe... ... 10, 11, 12, 13 Chevy Silverado, Tahoe, Suburban and GMC Sierra, Yukon Denali ...2007-2011 Tahoe Yukon Suburban Escalade Vent Section ...Missing: terrain
    How To Install Remove Rear Outside Door Handle 2007-13 ...
    ? 10:02
    https://www.youtube.com/watch?v=7ZUTqqEzpZg
Need to replace interior door handle
First remove interior trim panel and the interior handle is rivited onto the doors inner panel.
I have a 2000 GMC Sierra. The Driver side interior door handle no longer opens the door. I know this is a problem with all vehicles of this model. What is most likely wrong and how do I fix it?
have to remove panel to access back of handle if plastic retainer to rod broke off than easy fix just reclip if the handle broke in two which is the more lkely than need to replace salvage yards cheaper and quicker for part -online about 18 to 25 for replacement -or dealer to replace it the handle surround is pop riveted in place drill out replace with a screw and exchange the rods from old to new
Installing driver side interior door handle
pull the inner panel off by first un screwing the two screws located on the handle portion of the panel(they may have plastic hadeaway covers over the heads) then remove the window rolldown handle(if so equipped,manual window)then pull the plastic trangle from the inner of the mirror(this little tri angle keeps the trim down and secure on the door. then pull the palnel directly out there are small clasp pins in behind the panel try not to break these(but they do sell replacements at your local auto store) you will have to get ALL of these free then wiggle the panel up releasing it from the inner shell of the door and and window. you should now have a clean view of the handle. you will now need to droll out the rivit holding the handle to the inner steel of the door. pull the handle forward and it should be released from the inner steel now there clips holding the "rods" to the handles back side, they should have a little piece clipped to the rodto un clip these you need only push them off with your thumb. then replace handle with the new one, and uce a large steel screw to secure the handle when replacing back on door.
2helpful
2answers
I have taken the door panel off of my '98 GMC Sierra to fix my door handle, which does not work anymore. It has no resistance against it, and moves side to side without even trying to open the door. When i...
Broken inside door handles are a common problem and there is not an easier way of fixing problem.drill out head of rivet with a 3/16 drill bit.Then slide handle assy. from panel.To install new handle attach the two rods you removed .Then slide new handle back into the slots and replace the rivet.
1helpful
DOOR HANDLE INSIDE BROKEN 98 SIERRA
It helps to have a flat pry tool to get the door panel off but, other than that it's not too hard. Autozone has a tool in the help section that is made to work with those and they have the replacement push clips that always seem to break.
2helpful
3answers
How do you repair a gmc sierra 1998 inside door handle
You have to remove the door panel, if you have roll down windows the handle will have to be removed. After panel is removed you have to drill the one rivet that hols the interior handle. slide the handle down and unfasten the rod retaining clip. Please make sure you do not break the clip. Install the new interior door handle, clip and provided fasteners. Try the door before you install the interior door panel, Note the is a good time to lube the window roller and the door mechanism. Make sure to install the water shield to provide the protecting from the elements. Line all the plastic retaining clips and or replace if they are broken. Good Luck.
1helpful
Replacing an interior door handle
first remove the door panel after you have completed that remove the 3 bolts holding the handle in place, pull the handle out on the reverse side there will be a connecting rod with a retainer clip holding the rod to the door handle remove the retainer clip and rod and remove the broken handle follow instructions in reverse to reinstall new handle
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
