My printer turns on and acts like it wants to print but wont grab the paper. What happened to my printer its really not that old...but it would jams a lot before this. Help!
I have no Idea what you are talking about. I looked back there and see a thing that grabs the paper but it doesnt look dirty and nothing is moving. its just making noises like it wants to.I have no Idea what you are talking about. I looked back there and see a thing that grabs the paper but it doesnt look dirty and nothing is moving. its just making noises like it wants to.
AnonymousMar 30, 2009
Will not feed the paper into the printer.
Mine wont feed paper either it sounds like its working but its not. Mine wont feed paper either it sounds like its working but its not.
You can't post conmments that contain an email address.
Hi! Try to check for any obstruction. Fan the paper as well on the paper tray. Closely check the mechanism as well when it acts like grabbing the paper. If all fails. Call Epson for a replacement. Hope this helps.
if you remove paper tray you will see rubber feed rollers that pickup the paper, sometimes when they really dirty they wont feed the paper, you can try cleaning them with some windex or alcohol but do no try to rotate them as there is a clutch and it can break, after gently cleaning the rollers wait a few minutes to dry, and try printing again... if still having a problem it may be either the rollers are worn or some other mechanical problem.
f your printer is unable to pick up paper and the feed rollers are
turning, remove the rear access door and clean them with a cloth
moistened with water.
i just thought i had the same problem... but you know how there are 2 buttons on the front of the printer once the paper output tray is down? the bottom of those 2 i think switches it back and forth between paper feeding from the normal, top spot, and from somewhere else, so you can try pushing that button! worked for me!
Placing one sheet at atime is worse usually as these units feed off a minimum level. Keep them topped up to at least no less than 10 sheets. The printers sound like the have a paper feeding issue. Could be a jam. Open unit, check for paper jam. Cheers lilacgerry xxx
