Doesn`t this unit already come prewired for electric
heat? It shows 5kw,1okw and 20kw.
What heat kit do you have-should be on box that you took
element out of
Kit 2PH08510506- follow step 1
-Attach Blue lead wire (711) to the bottom terminal of the field wiring terminal Block
-Attach Orange wire (702) heater lead wire to the M1 position of the sequencer
Kit 2PH08510706 and Kit 2PH08511006
-Follow Step mentioned above and this next step:
-Attach Blue lead wire (709) with wire (711)
-Attach Red Wire (701) to M3 position of the sequencer.
Since you are adding another heat strip -these instructions are only a reference. However it seems
pretty simple, if you have a M# terminal on the control board.
Good Luck
This is a package unit heat pump with additional heat strip. Misplaced the info to wire in jumpers and to activate the emergency heat strip.
Sorry --- this unit was installed last year, the heat unit within was not wired at that time ... heat pump works fine ... until now in sunny Central Florida, hah!
Simply need only the wiring info to complete this project. Thanks to anyone who has this or a link to this info.
