Ce a recent service I have a problem with my oil pressure warning coming on then going off, then coming on again, I have had a oil pressure test done on the vehicle, which was ok, I then had a new sensor fitted, but it is still happening, I wondered if I could have a suspect oil filter, or maybe a computer problem, could someone please advise.
Check the oil pressure wire attached to the gauge usually in the engine compartment. Dirt can interfere with the signal causing a short which will give you the symptoms you describe. Hope this helps
Testimonial: "Thanks for the promt response,,but this has already been done/"
I have the same exact problem. my oil pressure light went on, it realli worried me so i took it to my mechanic, and he said the oil pump isnt pulling enough pressure. oil pump is around $260 labor $200. i wonder if you fixd your problem maybe your experience could help?? my e-mail addres is [email protected]
