My liftmaster 1265 just had the dive/worm gear replaced after they stripped. I replaced the bushing and gears. The door won't travel more than 8 inches toward the closed position from the full open position (where it is now) with the opener. The safety sensors don't appear to be the problem. I checked the limit switch adjustment and it looks ok. Even unhooking the door from the chain doesn't seem to help, same reaction..8 inch travel and reverse. Any ideas? I tried maxing out the downword pressure and it didn't help.
Check, The black interruptor cup. See if it has powder from gear on it , Remove particles, And run a Q-Tip between the two little towers on the RPM sensor, Which the interruptor cup rotates into to count rpm cycles.
