If you have a soldering iron simply epoxy the jack down to the board and then take some wire and solder rthe center conductor of the RCA jack and the other end would go to the trace on the PCB. Do the same for the ground connection.
Yes. Rockford fosgate has a cover over all of the connections, crossovers, and various other controls. Just remove the cover with the allen wrench they sent with the amp or find a set of allen wrenches if you don't have one. Under this cover you'll find what you're looking for.
rockford fosgate use hexfets.they are made by international rectifier and are available from toronto. they are n and p channel devices.they are not bipolar transistors...
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
