Resetting the phone
If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a
reset.
There are two types of resets-soft resets and hard resets. In a soft
reset,
all records and entries are saved. In a hard
reset, all records and entries
are erased. If you must do a hard
reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft
reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the
reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
rest code/master unlock code
Got mine from TCM in NY while on holiday. accidentally locked it now it won't unlock. I called TCM but they said they can't help. $45down the drain!
Someone set a lock code on my Kyocera Phantom KE414 phone and I need to get the unlock code.
