My hamilton beach custom grind coffee grinder will not turn on anymore. The outlet works but pressing the grind button no longer activates the motor.
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Yeah! This was our problem! Now I need help with the "then you can easily fix it" part. How?
How can the safety latch be fixed if it is out of alignment?
I just bought my unit. Straight out of the box
Where is the lock switch?
