Instruction for installing Evenflo Triumph Car Seat. We are the grandparents and our granson is staying with us for a few days. Our daughter is loanig us their car seat, but won't be there to help instal...
On the back of the car seat you should have a black hook with a safety latch on it connected to a adjustable strap. You will require an anchor point to connect this to in the back of your car, depending on your car (sedan, station wagon,4x4 ect) your anchor point will have a small removable cover over it about 1 inch square or so, if you have not got one already installed make sure you get the anchor as well. This will be a small metal latch with a spacer and bolt with a safety nut the nut goes under the bottom of the parcel shelf if it is a sedan if not you won't need the nut. The the hook will attach to the anchor and then you just loosen the adjustable strap out until it is fairly loose (about 3 or 4 inches of play between the car seat and the baby seat will be fine) now if the baby is small and needs the seat to lay down ie they can't hold there head up or are to small to face forward, have the head end of the baby seat to the front of the car and set the seat belt throught the hole thats horizontal to the car seat. If they can face forward same thing just stand seat upright and feed the seat belt through the horizontal holes. The hole for the seat belt should be about 2 to 3 inches high and about 4 or 5 inches long. Just becareful not to put the seat belt over the childs belts on the baby seat. Then just tighten the adjustable ******** the baby seat until firmly tightened against the car seat and you are done. The baby seat will still move a bit from side to side but if it moves more than 3 inches or so tighten the adjustable strap even more.
