1998 Oldsmobile Regency Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do your repair the heater in 1998 olds regency? The temperature readout flashes, the temperature gauge on the dash is not working, it blows hot out of one vent on bilevel setting.
buzz flewhart
Level 3:
  • Oldsmobile Master 655 Answers
  • Posted on Dec 02, 2009
buzz flewhart
Oldsmobile Master
Level 3:
Answers
655
Questions
0
Helped
193770
Points
1844
Sounds like the heater control unit is going bad. I believe this unit has a digital/vacuum control unit which explains why you are only getting hot out of one vent. Try the salvage yard or ebay for a replacement unit. They are non-repairable...
1helpful
I have a 98 Bonneville, the heater/defroster is blowing out cold air. I drove around for 30 to 40 minutes checked the radiator and it was cold to the touch. could it be the thermostat
The dash gauges are notoriously inaccurate. But it is possible that the thermostat is stuck open. Does the upper radiator hose get hot after engine warmed up? Also feel both heater hoses-when engine is warm, both should be hot-indicating the coolant is circulating through the heater core. If heater hoses are hot, and you still have cold air, the temperature blend door on the heater case may not be operating.
Try a new thermostat and see if engine warms up faster and better.
1999 VW Cabrio dash light
Obviously it's temperature gauge light. Check for coolant level first. Then check for coolant leak. If coolant is leaking out of your car, the lower coolant levels in your engine will cause it to overheat. If you have your heater on and it starts blowing hot air instead of cool, your engine is low on coolant. This will cause to flash a warning light on your car's dashboard.
1helpful
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
No heat from vents
Heater blows cold?
These will help.
Thanks.
2answers
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
1helpful
94 dodge intrepid blows kinda warm but not very warm what do I do? We changed the thermostat
Since your blower is working and it is a heat issue,thats where we'll start,First thing is have you checked the coolant level in the radiator when engine is cold,make sure it is filled to top,next verify you have coolant in reserve ,Start your van and get it up to normal operation temperature,If your heat gauge on the dash works correctly it should be 190 degrees,Now lift the hood and locate the two heater hoses going into the heater assembly at the fire wall,Both hoses should be hot to hold on to,if both are hot and no heat inside your problem will be the blend air door in heater assembly.
if neither hose is that hot you need to replace the thermostat in the engine to get it up to 195 degrees.
if one hose is hot and one is luke warm then the heater core is blocked and to blame. hope this helps you.
1helpful
My car heater is blowing cold air
The shut off valve on the heater core was left shut during the repair on your coolant system. the repairman forgot to re open the shut off valve . this is the problem. open the shut off valve and, the air will become hot again. as for the gauge fluctuations, the actual gauge may be malfunctioning.
1998 GMC Jimmy SLT warm air only from heating ducts
if you claim that your heater core is flushed properly then my bet is the temp regulator is bad.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
