Your bike is flashing out ECM codes. It will flash out the first digit of the code in flashes .5 seconds apart. It will then pause (lamp off) for 1.2 seconds and flash out the second digit. If this is what your seeing it sounds like it's flashing an ecm code of '11' which for a Delphi fuel system equates to 'battery voltage high'.
If you are jump starting your bike from a car, I'd recommend doing so with the car's motor turned off. This is because the charging system for a car is a lot more powerful that that of a bike and you might actually damage the charging system of the bike (blow out the voltage regulator).
The Drain plug is at the bottom back of the Primary. After Drianing the old oil remove the bonnet cover and add one OT of Oil.
Thanx Dave, I appreciate the feedback. I hope I didnt screw anything up with my bike.
