I c an't because only see the HD from my computer and when i try to open the drive nothing happens.I c an't because only see the HD from my computer and when i try to open the drive nothing happens.
the problem still, i need a solution because the drive have information valuable.the problem still, i need a solution because the drive have information valuable.
You can't post conmments that contain an email address.
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
If you have a look at the link below, you will be directed to a page which will give you step by step instructions on how to scan and recover bad sectors on your hard drive.
Feel free to let me know if you have any further questions.
you need to scan your external hard drive for bad sectors problems, you can use winpe mini cd, its a live cd that have hirens boot disk inside it as well as a preinstalled windows eviorment that will give you access to many tools and softwares...download it , burn it to disk and boot it.....
the idea is when you was copying files, some read errors occured that crashed the system, and whene the system crashed, bad sectors/clusters appears, and they need to be scaned and fixed.
Try this go to my computer. Right click on your removable. Go to properties tools error checking :mark both boxes and hit start. This will check file system errors and try to recover bad sectors.It will also tell you if the drive is failing.
Hope this helps.
Please leave feedback.
