I recently had the E74 system error which started with as ‘black snow’ on the screen. There is an extended 3 year warranty that covers E74 and 3 Red Lights errors only.
I looked in to fixing it myself but thought might as well let someone else graze their hands getting the case off!
Despite the horror stories of it taking forever MS seemed to have pulled their finger out and made this a very efficient process, I got mine back within a week (I live in the UK and repairs get shipped to Germany).
Here's a quick breakdown of the process:
1. Go to www.xbox.com/support and click on the relevant link relating to your problem.
2. Go through the walkthrough. If you've still no joy you can click a link to pick whether you are a US resident or not.
3. Type in serial number of the console (you don't need any receipts, I bought mine off eBay).
4. They send you a shipping label and a link to arrange UPS to come and pick up your console.
5. Bite your nails and rock manically in a corner until your console comes back (you can track the whole process at xbox.com).
I've sent back a first generation 360 and an Elite. Certainly worth considering as they will repair or replace your console!
http://support.microsoft.com/kb/907534 3 Red Light (Red Ring Of Death/RROD)
http://support.microsoft.com/kb/941377 E74 Error
That's the ring of death, i've yet to see someone get their xbox fixed with that problem, it seems to be common with xbox 360
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
XBOX 360 Red Light error, or Red ring of Death RORD is a
very common issue, and can happen anytime.
There are different Error numbers related to RoRD, and appears on screen
starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair
guide available that covers this problem and also all other common XBOX
problems. You can get your copy XBOX 360 Repair Guide, you can download it and
get help to fix your console. Please feel free to message me if you need
further assistance
click here to download.....................
