Question about Black & Decker SpaceMaker ODC440B 12-Cup Coffee Maker
Water reservior spills the water trying to push button to put in also the light is not working i got it for xmas modelodc440white do i have adefective pot? not satisfied with it i loved the old space
Bad pot odc440wht
  • rose1 Jan 14, 2008
    thanks anyway but you did not mention the light or maybe i put the info in wrong place i put it at instead of the wrong huh
    Problem Solver:
  • 14 Answers
Try contacting your warranty service at Black and Decker if your machine is under warranty. If you don't know then you should be able to call and find out. I don't have the number for them but a quick internet search should find it or if you have your user manual then all information should be inside.
Posted on Jan 14, 2008
  • coffeediva22 Jan 15, 2008
    Water reservior spills the water trying to push...
    That is all your post has on info so I wonder how my posted solution was innapropriate???? Thanks, but next time you could rate it as "Thanks for trying" instead. Have a nice day
Radiaor is pushing water back out of reservior and over heating
Radiator must be rodded out at radiator shop.
Feb 08, 2013 | Water Heaters
Just got a new Keurig mini. Plugged it in, put in the water, closed the lid, put a cup on the plate, pushed the power button, pushed the "coffee cup" button and nothing is happening.
My wife's mini single cup B31 quit dispensing hot water into the K-cup. It would go through every stage and the pump came on but no water, no coffee. Try this: unplug the unit, take the drip tray off and lay the Keurig on its back, with the top opened so you can see the dispensing probe and the rubber ring that seals to the top of the K-cup. The dispensing probe is sharp, with two small channels, one on each side. (Be sure you can spill a little water when you try this) With a kid's water blaster, or a rubber bulb, squirt water up the channels on each side of the probe. Do this a few times, then try to run it normally.
That worked for me, and loosened the few coffee grounds that were plugging the outlet.
Mar 14, 2010 | Keurig Coffee Makers & Espresso Machines
Dryer quite
my dryer worked fine before xmas but washed a load of clothes and temped to put clothes in dryer and put it on right settings and pushed button to start it and nothing. We tried the breaker and shut everything down for about 5mins. and started it back up and tried the dryer again and still nothing had friend look at it and looked online and I think it maybe the start button myself.
Dec 27, 2008 | Dryers
Hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
F7425-900 hoover steam vac
There is a valve at the bottom of the tank, push it in and see if it goes in and out ok. The tank sits on the reservior asm., a rod in the handle pushes it when you squeeze the trigger. You may have a problem with the rod not releasing or a bad reservior asm.
Apr 26, 2008 | Hoover F7431-900 SteamVac Vacuum
My Hoover floormate H3000 won't put out any solution.
Check the valve at the bottom of the tank, push it in to see if it releases the water ok. The tank sits on the reservior asm. the rod inside the handle hits this asm to release the water. Watch the rod as you squeeze the trigger to make sure it is hitting the asm. If it is then the reservior asm is bad, if not then a problem inside the handle.
Mar 07, 2008 | Vacuums
Cleaning solution continually runs from clean solution tank
Where is the water running out? If at the bottom of the tank, is the seal on where the tank sits on, Maybe the rod inside the handle is staying pushed down, the reservior asm is bad, or a water line is off.
Feb 12, 2008 | Hoover F5881-900 Vacuum
Hoover will not release water/solution
Maybe the reservior asm(#24). isn't working, when you push the trigger, it pushes a rod inside the handle to hit the reservior asm. so the water will release. Could be the rod isn't hitting the reservior asm. Maybe these pictures will help.
Dec 02, 2007 | Hoover H2800 Stick Wet/Dry Vacuum
Black & Decker SpaceMaker  ODC440B 12-Cup Coffee Maker Logo
121 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
