Heating & Cooling Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ihave a force gas heater that has a problem
GOS80904BND heater. For the last four years I have had problems with the heater initing after the temperature drops in the house. The system tries three times than shuts down. A tech will come and turn off main switch and turn back on and it will work. They can not diagnosis the problem
Anonymous
Level 3:
  • Master 1,515 Answers
  • Posted on Nov 25, 2009
Anonymous
Master
Level 3:
Answers
1515
Questions
Helped
629096
Points
4388
Hi, after the heater starts again and warms the home up and shuts down, do you have to turn off the switch to get online every time? I hope they haven't charged you for all of these service calls.I may not have the answer, but It should have a flame sensor on it that may be dirty. It would be next to the pilot with the rod of it in the pilot flame. If it does, clean it with steel wool, no sand paper.See if this takes care of the problem. Let me know so we can find the solution for you, this is crazy coming out and doing nothing to find the problem. Let me know Please!
Sincerely,
Shastalaker7
I HAVE A ALL-PRO SPC-85 HEATER. IT WILL LIGHT AND RUN, BUT IT SEAMS TO NOT BE GETTING ENOUGH GAS. WHAT CAN I LOOK FOR?
Your gas pressure is regulated by the gas valve .You will need a special tool to check gas pressure on the gas valve .
Make sure burners are clean ,filters and blower wheel .
A lot of time dust settle on blower wheel and make it harder to spin causing reduction on air movement
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
1helpful
2answers
Hi i have a dyno glo pro heater model number RMC-KFA170TDGP it worked great last year this year its been nothing but a pain flames shoot out the front by times sounds like its getting to much air but the...
did you try cleaning the lens of the photocell, they git dirty from smoke ver time which regulates the flame or replace the nozzle, sounds like it could be getting plugged up? usually any heating store would have a nozzle for a couple bucks if you get the number off it. the nozzle is right where it comes out and they are common to plug up at times with wear
Ihave a R60A heater that when I turn it on it
This is in referance to the R60a 60,000 B.T.U. Multi fuel heater
Sounds like the your ignitor has burned out. Had the same problem. Now looking for a replacement. Checked mine and for some reason the filiment has broken/burned off. Ran across this on a search for one. Good luck!
1helpful
Storage
Kerosene does not get stale or go bad like gas. I would make sure the tank is close to full to prevent condensation and just put it away in a dry place. I have stored over 50 each year for many years and have never had any problems.
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Top Heating & Cooling Experts
Paul Carew
john h
