My Nikon D60 keeps freezing up. Sometimes when I go to take the picture it works fine and other times, it won't take the picture but if I hold down the button it will eventually take after a few seconds. I've more than likely switched a setting but I don't know which one and how to set it back to the default settings.
The D60 won't save pictures anywhere other than the memory card. If you can playback your pictures by pressing the playback button (marked with a right-pointing triangle), then they are saved on the card.
The display on the back is for the menus, reviewing pictures already taken, and shooting information. The D60 works as SLRs have worked for half a century: you use the viewfinder to compose your picture. The LiveView feature is a recent development in digital SLRs. Nikon introduced it into their cameras with the D3 and D300. The D60 is designed as an introductory model and lacks this feature. Sorry if that wasn't the answer you wanted to see, but there it is.
The camera has to be turned on and in the review mode. You can also try using just the SD card. If your computer doesn't have a slot for the card, you can buy a card reader (sort of an adapter) that will hold the card and plug into a USB port for less than twenty dollars.
No, you have done nothing wrong. The D60 does not have the preview function on the monitor like the compact digital cameras. Nikon gave that function a name. It is called 'Live View'. The newr models like the D90 do have that feature. You can read further about your D60 here: www.digitalcamera-hq.com
I would start with a freshly formatted memory card. Erasing images leaves folders and other unneeded data on the card which can slow the write speed down considerably. Secondly, make sure the front and rear elements of the lens are spotlessly clean. The auto focus works best (faster) if it can see the subject with perfect clarity.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick.
Tonya
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
