Home | Audiophase | MDP-1 Personal MiniDisc Player | I am havin a major pro...
Audiophase MDP-1 Personal MiniDisc Player
Problem for Audiophase MDP-1 Personal MiniDisc Player
I am havin a major problem
By Pain54 on Jan 11, 2008
my new kz112 will not hold a charge i let it charge for 3 and a half days and nithing. it only holds a charge for like 6 seconds then days low batt and turns off. what do i do?
Best Solution
posted on Jan 22, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
When you plug it up to the computer had it off. Then you need to wait about 5 sec. let the computer screen come up on the mp3 player. Now which it to on. There is a little box in the right upper corner wait to see if it looks like it is fulling up if it does it is charging.
Solution #2
posted on Nov 03, 2008
Very Helpful)
kiapolo2002
Rank: Apprentice
Rating: 92%, 2 votes
Here is a more detailed way to do this. I have the same problem with this. Mine just seems to last last longer with the charging though.
  1. Plug it into your computer's usb port.
  2. Wait until your computer recognizes the device. When you hear it make a sound after the device is plugged in, you turn the switch to the "ON" position and just leave it there.
  3. Every now and then, shut it off and unplug it, and then repeat steps 1 and 2. I have found that after a while, the device stops charging on its own (which drains the battery without you knowing it) and then when you go to use it, you can't because of a dead battery even though it was plugged in. Like I said, the best way to get around this problem is to unplug the and then plug it back in every 30 mins or so to keep it charging. A good way to know if your MP3 player is still connected and charging is to add tracks to it. If the download bar stops moving forward, then that means your device is no longer connected and charging. It also means that you will have to replace the file that you tried to put in the player.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't walk....run to the store and return the item. It has a history of issues!
Popular Solutions for Audiophase MDP-1 Personal
Questions and Unsolved Problems for Audiophase MDP-1 Personal
Do you recommend Audiophase MDP-1 Personal MiniDisc Player?
Answer
Answer
when i press play on my audiophase kz112,it tells me it has a flash error and to back up my files... (More)
Answer
when i added songs to my player i went to open it and it wouldnt open
Answer
when i wanted to put more music on my player i put it on their nd when i tried to turn it on it... (More)
Answer
My girlfriend bought me an audiophase kp 1000 when I upgraded to WMP 11. I have Windows Vista as an... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Audiophase MDP-1 Personal...:
Top Personal Audio Min... Experts
Rank: Guru Guru
Solutions: 1445
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Personal Audio Min... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
