I would check the fuses first. Headlights are typically on a separate fuse then the parking lights. If the fuse is fine check and see if the Bulb is burnt out but it is rare for both lights to go out at the same time.
Did you test the low beam electrical circuit using a volt meter ? Look at a wiring diagram to see what all is involved in turning the lights on ? Do you know how to test electrical circuits ?
Also reading service repair manual about the head lamps opp. would be a good thing to do .
Headlamps
The major common components of this system are the body control module (BCM), ambient light sensor, multifunction switch, park brake switch, and the headlamps.
The headlamps may be turned on in 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, normal operation occurs. Second, with the headlamp switch is placed in the AUTO position, automatic lamp control (ALC) occurs. During ALC control, the headlamps will be in daytime running lamp (DRL) operation in daylight conditions, or low beam operation in low light conditions.
The low beam relay and high beam relay receive battery positive voltage directly from the battery through the HDM and COILS fuses in the underhood fuse block. The BCM supplies a ground signal to the low beam relay coil for automatic headlamp control and normal headlamp operation. The BCM also supplies ground to the high beam relay coil for high beam headlamp operation. When the driver places the headlamp switch in the HEADLAMP position and the dimmer switch is in the low beam position, the low beam relay energizes sending current flow through the left and right low beam headlamp fuses to both low beam headlamps. The dimmer switch sends a ground signal to the BCM in the high beam position and a momentary ground signal in the flash-to-Pass (FTP) position from G102 to deactivate the low beam headlights and activate the high beam headlights. With the headlights in the low beam position, the high beams may be momentarily turned on or flashed by activating the FTP portion of the switch.
Low Beams - Standard
The standard low beam headlamps receive voltage from the headlamp driver module located in the underhood fuse block. The body control module (BCM) controls the headlamp driver module with the headlamp low beam relay control circuit. Low beam control is determined by a signal on the headlamp dimmer switch signal circuit from the multifunction switch. When the headlamps are requested ON and the headlamp dimmer switch signal circuit is open, the BCM sends a pulse width modulated (PWM) ground signal though the headlamp low beam relay control circuit to the headlamp driver module which illuminates the low beam headlamps at a 100 percent intensity level. The right and left low beam circuits are independent and are fused separately in the underhood fuse block. The LOW HDLP-RT 10A fuse supplies voltage to the right low beam headlamp and the LOW HDLP-LT 10A fuse supplies voltage to the left low beam headlamp. The right and left headlamps are grounded at G103 and G107 respectively.
Your best bet mite be to have a qualified technician check it
High beam and low beam are different circuits in the lamp socket. Try probing with a volt meter or test light at the head lamp socket, or try with new head lamps.
Seems like if your other low beam is lit, there's something wrong with the new bulb. Make sure it's the exact type needed, and switch the working bulb from the pass. side to drivers side to check.
Saturn what , ION , VUE , L300 LW300 ? Did you check the fuses ? 2.2 l headlamp relay . The lights are controlled by the BCM - body control module .
The headlamps may be turned ON 2 different ways. First, when the driver places the headlamp switch in the HEAD position, for normal operation. Second, with the headlamp switch placed in the AUTO position, during operation in low light conditions.
On vehicles with manual headlamps, the LH HDLP and RH HDLP fuse in the fuse block - underhood, supply battery positive voltage to both low beam lamps and high beam lamps at all times. The low beam and high beam circuits continue through the fuse block - underhood, through the body control module (BCM), and to the headlamp switch. The low beam or high beam circuit then, depending on the position of the dimmer switch, continues through the headlamp switch. When the headlamp switch is placed in the ON position, it provides a ground path for the low beam or high beam lamps through G203. The low beam and high beam circuits are monitored by the BCM.
I don't think this is a fuse problem ! more then likely a headlamp switch or dimmer switch or a ground problem or relay if your vehicle has 2.2l engine !
I I
no year, is it a 1973 Civic?
water there is 100% normal, huge water forces there... at 85mph.?
why not post the symptoms so we can help?
are both lamps dead, left and right????????????
yes, fuses. all fuse in both boxes, they are marked head lights.
most cars , not all have 2 fuse. one for each lamp. so both dont die
together, (big danger that)
if one lamp is dead, use a voltmeter, at the lamp
got 12vdc there, HL switch on, then the lamp is burned out.
measure at the socket, connected.
Check for loose contacts in the light socket. Also, most vehicles use separate relays for passenger and driver side headlights, so be sure to check those.
Both your low beam and your high beam is protected by the same fuse, so it makes sense that the fuse is OK if the high beam is working on the passenger side. There are 3 fuses for the headlamps. Fuse #13 in the Battery Junction Box (20 Amp). If this fuse is blown, the headlamp relay will not have any power and neither high nor low beam on either side will work (you will have no headlamps at all) Then there is Fuses #2 and #3 (15 Amp) in the Battery Junction Box. #2 goes to the left low and high beam and #3 goes to the right low and high beam.
The headlamp switch uses a SINGLE CIRCUIT to control BOTH sides at the same time, so if one side works, the switch cannot be the problem. The headlamp relay provides power for fuses #2 and #3 and we alreadyascertained that these fuses must have power since we have working lights on both sides, so the relay cannot be the problem. A replacement bulb has already been tried, so that pretty much leaves us with a bad lamp socket. (Most likely cause) or a bad connection at splice #S122, which is located in the main wiring harness near the breakout for the left headlamp. (RED/BLACK wire)
First verify that the switch is energizing the relay in both positions by turning the low beams on and then pulling up the relay--does it click? If not, replace the switch. If yes, next check for power on the red wire as it comes out of the column. Switch on, no power--replace the switch. If power, check for power at the head-low fuse in the engine compartment fuse box. No power--find break in wire. If power, check for power on the yellow/red wire as it comes out of the fuse box. No power--repair fuse box. Power--check for power at lamps--same wire. No power--repair yellow/red wire.
